system.vision.getWindow
Backwards Compatibility
This function replaces system.gui.getWindow. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Finds a reference to an open window with the given name. Throws a ValueError if the named window is not open or not found.
note
This function is available on secondary desktops via the system.vision.desktop function. See the Multi-Monitor Clients page for more details on secondary desktops.
Syntaxβ
system.vision.getWindow(name)
Parametersβ
| String | name | The path to the window to field. |
Returnsβ
Window - A reference to the window object, if it was open.
Scopeβ
Vision Client
Code Examplesβ
Example #1
# This example will get the window named 'Overview' and then close it.
try:
window = system.vision.getWindow('Overview')
system.vision.closeWindow(window)
except ValueError:
system.vision.showWarning("The Overview window isn't open")
Example #2
# This example will set a value on a label component in the 'Header' window.
try:
window = system.vision.getWindow('Header')
window.getRootContainer().getComponent('Label').text = "Machine 1 Starting"
except ValueError:
system.vision.showWarning("The Header window isn't open")
