system.vision.exportHTML
Backwards Compatibility
This function replaces system.dataset.exportHTML. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Exports the contents of a dataset to an HTML page. Prompts the user to save the file to disk.
Syntaxβ
system.vision.exportHTML(filename, showHeaders, dataset, title)
Parametersβ
| String | filename | A suggested filename to save as. |
| Boolean | showHeaders | If true, the HTML table will include a header row. |
| Dataset / PyDataset | dataset | The dataset to export. |
| String | title | The title for the HTML page. |
Returnsβ
String - The path to the saved file, or None if the action was canceled by the user.
Scopeβ
Vision Client
Code Examplesβ
Code Snippet - Export then Open
# This snippet prompts the user to save the data currently displayed in a Vision Table component to an HTML
# file, and opens the file in the default web browser after a successful save.
table = event.source.parent.getComponent("Table")
filePath = system.vision.exportHTML("data.html", 1, table.data, "Production Report")
if filePath != None:
system.vision.openURL("file://"+filePath)
