system.vision.openDesktop
Backwards Compatibility
This function replaces system.gui.openDesktop. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Creates an additional Desktop in a new frame. For more details, see the Multi-Monitor Clients page.
note
Syntaxβ
system.vision.openDesktop ([screen], [handle], [title], [width], [height], [x], [y], [windows])
Parametersβ
| Integer | screen | The screen index of which screen to place the new frame on. If omitted, screen 0 will be used. [optional] |
| String | handle | A name for the desktop. If omitted, the screen index will be used. [optional] |
| String | title | The title for the new frame. If omitted, the index handle will be used. If the handle and title are omitted, the screen index will be used. [optional] |
| Integer | width | The width for the new desktop's frame. If omitted, frame will become maximized on the specified monitor. [optional] |
| Integer | height | The height for the new desktop's frame. If omitted, frame will become maximized on the specified monitor. [optional] |
| Integer | x | The x coordinate for the new desktop's frame. Only used if both width and height are specified. If omitted, defaults to 0. [optional] |
| Integer | y | The y coordinate for the new desktop's frame. Only used if both width and height are specified. If omitted, defaults to 0. [optional] |
| PySequence | windows | A list of window paths to open in the new Desktop frame. If omitted, the desktop will open without any opened windows. [optional] |
Returnsβ
JFrame - A reference to the new Desktop frame object.
Scopeβ
Vision Client
Code Examplesβ
Example #1
# Create a list of window paths to open in the new desktop.
windowsToOpen = ["Main Windows/Main Window", "Navigation"]
# Creates a new desktop. The desktop will open the windows listed above.
system.vision.openDesktop(windows=windowsToOpen)
Example #2
# Creates a new desktop on monitor 0 (primary) with only the Overview window open.
system.vision.openDesktop(screen=0, windows=["Overview"])
Example #3
# Including a handle gives the new desktop a name. This is useful for using other desktop scripting functions
system.vision.openDesktop(screen=0, handle="Left Monitor", windows=["Overview"])
