Version: 8.3
system.vision.lockScreen
Backwards Compatibility
This function replaces system.security.lockScreen. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Used to put a running client in lock-screen mode. The screen can be unlocked by the user with the proper credentials, or by scripting via the system.vision.unlockScreen() function.
system.vision.lockScreen([obscure])
BooleanobscureIf true(1), the locked screen will be opaque, otherwise it will be partially visible. [optional]
Nothing
Vision Client
Code Example​
Code Snippet
# This would run in a timer script to lock the screen after 15 seconds of inactivity, and then log the user out after 30 seconds of inactivity.
if system.vision.getInactivitySeconds() > 15 and not system.vision.isScreenLocked():
system.vision.lockScreen()
elif system.vision.getInactivitySeconds() > 30:
system.vision.logout()
