system.opchda
OPC HDA Functionsβ
The following functions give you access to interact with the HDA types of OPC servers.
For more information on OPC HDA, see the OPC HDA properties section of the History Providers page.
If you are looking for an OPC HDA server to use, various OPC HDA server tools are available, such as Matrikon and Kepware.
ποΈ browse
Performs a browse at the given root.
ποΈ getAggregates
Will query the server for aggregates that it supports.
ποΈ getAttributes
Queries the given server for the item attributes that are available with system.opchda.readAttributes.
ποΈ getServers
Returns a list of the OPC-HDA servers configured on the system.
ποΈ insert
Insert values on the OPC-HDA server.
ποΈ insertReplace
Will insert values on the OPC-HDA server, or replace them if they already exist.
ποΈ isServerAvailable
Checks to see if the specified OPC-HDA server is defined, enabled, and connected.
ποΈ readAttributes
Reads the specified attributes for the given item over a time range.
ποΈ readProcessed
Reads processed values from the OPC-HDA server.
ποΈ readRaw
Reads raw values from the OPC-HDA server.
ποΈ replace
Replaces values on the OPC-HDA server if the given item ID exists.
