system.vision.getScreenIndex
Backwards Compatibility
This function replaces system.gui.getScreenIndex. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Returns an integer value representing the current screen index based on the screen from which this function was called.
note
This function is available on secondary desktops via the system.vision.desktop function. See the Multi-Monitor Clients page for more details on secondary desktops.
Syntaxβ
system.vision.getScreenIndex()
Parametersβ
Nothing
Returnsβ
Integer - The screen from which the function was called.
Scopeβ
Vision Client
Code Examplesβ
Example #1
# Prints an integer representing the screen from which the function was called.
print system.vision.getScreenIndex()
