system.vision.setConnectionMode
This function replaces system.util.setConnectionMode. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Sets the connection mode for the Client session. Normally a Client runs in mode 3, which is read-write. You may wish to change this to mode 2, which is read-only, which will only allow reading and subscribing to tags, and running SELECT queries. Tag writes and INSERT/UPDATE/DELETE queries will not function. You can also set the connection mode to mode 1, which is disconnected, all tag and query features will not work.
Syntaxβ
system.vision.setConnectionMode(mode)
Parametersβ
| Integer | mode | The new connection mode. 1 = Disconnected, 2 = Read-only, 3 = Read/Write. |
Returnsβ
Nothing
Scopeβ
Vision Client
Code Examplesβ
# This example, which could go in a project's startup script, would check the current username
# and set the connection mode to read-only if it is the "guest" user.
username = system.vision.getUsername()
if "guest" == username.lower():
# Set "guest" user to read-only mode
system.vision.setConnectionMode(2)
else:
system.vision.setConnectionMode(3)
