system.vision.getEdition
Backwards Compatibility
This function replaces system.util.getEdition. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Returns the edition of the Vision Client:
- Standard
- Limited
- Panel
Syntaxβ
system.vision.getEdition()
Parametersβ
Nothing
Returnsβ
String - The edition of the Vision module that is running the Client.
Scopeβ
Vision Client
Code Examplesβ
Example #1
# This code will write the Vision module edition to a text field on the same page.
event.source.parent.getComponent('Text Field').text = system.vision.getEdition()
