system.vision.closeWindow
Backwards Compatibility
This function replaces system.nav.closeWindow. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Given a window path, or a reference to a window itself, it will close the window. If the window can't be found, this function will do nothing.
note
This function is available on secondary desktops via the system.vision.desktop function. See the Multi-Monitor Clients page for more details on secondary desktops.
Syntax #1 (FPMIWindow Param)β
system.vision.closeWindow(window)
Parametersβ
| FPMIWindow | window | A reference to the window to close. |
Returnsβ
Nothing
Scopeβ
Vision Client
Syntax #2 (String Param)β
system.vision.closeWindow(windowPath)
Parametersβ
| String | windowPath | The path of a window to close. |
Returnsβ
Nothing
Scopeβ
Vision Client
Code Examplesβ
Example #1
# This example gets the window named 'Overview' and then closes it.
# If the window isn't open, a warning is shown.
try:
window = system.vision.getWindow('Overview')
except ValueError:
system.vision.showWarning("The Overview window isn't open")
Example #2
# This example would close the window named 'Overview' in one step.
# If the window isn't open, the call to closeWindow will have no effect
system.vision.closeWindow('Overview')
