system.vision.color
Backwards Compatibility
This function replaces system.gui.color. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Creates a new color object, either by parsing a string or by having the RGB[A] channels specified explicitly. See toColor to see a list of available color names.
tip
Syntax (String)β
system.vision.color(color)
Parametersβ
| String | color | A string that will be coerced into a color. Can accept many formats, such as "red" or "#FF0000" or "255,0,0". |
Returnsβ
Color - The newly created color.
Scopeβ
Vision Client
Syntax (int)β
system.vision.color(red, green, blue, [alpha])
Parametersβ
| Integer | red | The red component of the color, an integer 0-255. |
| Integer | green | The green component of the color, an integer 0-255. |
| Integer | blue | The blue component of the color, an integer 0-255. |
| Integer | alpha | The alpha component of the color, an integer 0-255. [optional] |
Returnsβ
Scopeβ
Vision Client
Code Examplesβ
Example #1
# This example changes the background color of a component to red.
myComponent = event.source
myComponent.background = system.vision.color(255,0,0)
