system.vision.getCurrentWindow
This function replaces system.nav.getCurrentWindow. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Returns the path of the current "main screen" window, which is defined as the maximized window. With the Typical Navigation Strategy, there is only ever one maximized window at a time.
This function is available on secondary desktops via the system.vision.desktop function. See the Multi-Monitor Clients page for more details on secondary desktops.
Syntaxβ
system.vision.getCurrentWindow()
Parametersβ
Nothing
Returnsβ
String - The path of the current "main screen" window - the maximized window.
Scopeβ
Vision Client
Code Examplesβ
# This code could run in a global timer script.
# After a 5-minute timeout, navigate back to the home screen.
if system.vision.getInactivitySeconds()>300 and system.vision.getCurrentWindow()!="Home":
system.vision.swapTo("Home")
# After a 5-minute timeout, navigate back to the Over screen inside the Main Windows folder.
if system.vision.getInactivitySeconds()> 500 and system.vision.getCurrentWindow()!="Main Windows/Overview":
system.vision.swapTo("Main Windows/Overview")
