system.vision.beep
Backwards Compatibility
This function replaces system.util.beep. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Tells the computer where the script is running to make a "beep" sound. The computer must have a way of producing sound.
Syntaxβ
system.vision.beep()
Parametersβ
Nothing
Returnsβ
Nothing
Scopeβ
Vision Client
Code Examplesβ
Example #1
# This will simply cause the system where the script is being executed to emit a beep sound.
# That system must have a way to produce sound, such as speakers or headphones.
