system.vision.exportCSV
Backwards Compatibility
This function replaces system.dataset.exportCSV. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Exports the contents of a dataset as a CSV file, prompting the user to save the file to disk. To write silently to a file, you cannot use the vision.export* functions. Instead, use the toCSV() function.
Syntaxβ
system.vision.exportCSV(filename, showHeaders, dataset)
Parametersβ
| String | filename | A suggested filename to save as. |
| Boolean | showHeaders | If true, the CSV file will include a header row. |
| Dataset | dataset | The dataset to export. |
Returnsβ
String - The path to the saved file, or None if the action was canceled by the user.
Scopeβ
Vision Client
Code Examplesβ
Code Snippet
# This snippet would prompt the user to save the data currently displayed in a Table component to a CSV file,
# and would open the file (in an external program, presumably Excel) after a successful save.
table = event.source.parent.getComponent("Table")
filePath = system.vision.exportCSV("data.csv", 1, table.data)
if filePath != None:
system.net.openURL("file:///"+filePath.replace('\\','/'))
