system.vision.getSibling
This function replaces system.gui.getSibling. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Given a component event object, looks up a sibling component. Shortcut for event.source.parent.getComponent("siblingName"). If no such sibling is found, the special value None is returned.
This function is available on secondary desktops via the system.vision.desktop function. See the Multi-Monitor Clients page for more details on secondary desktops.
Syntaxβ
system.vision.getSibling(event, name)
Parametersβ
| EventObject | event | A component event object. |
| String | name | The name of the sibling component. |
Returnsβ
VisionComponent - Returns reference to the sibling component. See VisionComponent.
Scopeβ
Vision Client
Code Examplesβ
# This example gets its sibling Text Field's text, and uses it.
textField = system.vision.getSibling(event, 'TextField (1)')
if textField is None:
system.vision.showError("There is no text field!")
else:
system.vision.showMessage("You typed: %s" % textField.text)
