system.vision.showColorInput
Backwards Compatibility
This function replaces system.gui.chooseColor. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Prompts the user to pick a color using the default color-chooser dialog box.
note
This function is available on secondary desktops via the system.vision.desktop function. See the Multi-Monitor Clients page for more details on secondary desktops.
Syntaxβ
system.vision.showColorInput(initialColor, [dialogTitle])
Parametersβ
| Color | initialColor | A color to use as a starting point in the color choosing popup. |
| String | dialogTitle | The title for the color choosing popup. Defaults to "Choose Color". [optional] |
Returnsβ
Color - The new color chosen by the user.
Scopeβ
Vision Client
Code Examplesβ
Example #1
# This code would be placed in the actionPerformed event of a button
# and would change the background color of the container the button was placed in.
parent = event.source.parent
newColor = system.vision.showColorInput(parent.background)
parent.background = newColor
