Version: 8.3
system.vision.showDiagnostics
Backwards Compatibility
This function replaces system.gui.openDiagnostics. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Opens the Client runtime Diagnostics window, which provides information regarding performance, logging, active threads, connection status, and the console. This provides an opportunity to open the Diagnostics window in situations where the menu bar in the client is hidden, and the keyboard shortcut (Ctrl + Shift + F7) can not be used.
system.vision.showDiagnostics()
Nothing
Nothing
Vision Client
Code Example​
Opening Diagnostics Window
# Opens the diagnostics window in a running client
