system.vision.playSoundClip
Backwards Compatibility
This function replaces system.util.playSoundClip. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Plays a sound clip from a .wav file to the system's default audio device. The .wav file can be specified as a filepath, a URL, or directly as a raw List[Byte].
Syntax - Using a Byte Listβ
system.vision.playSoundClip(wavBytes, [volume], [wait])
Parametersβ
| List[Byte] | wavBytes | A byte list of a wav file. |
| Float | volume | The clip's volume, represented as a floating point number between 0.0 and 1.0. [optional] |
| Boolean | wait | A boolean flag indicating whether or not the call to playSoundClip should block further script execution within the triggering event until the clip finishes. Useful in cases where code on lines after the playSoundClip call should wait until the sound clip finishes playing. [optional] |
Returnsβ
Nothing
Scopeβ
Vision Client
Syntax - Using a Filepath or URLβ
system.vision.playSoundClip(wavFile [, volume] [, wait])
Parametersβ
| String | wavFile | A filepath or URL that represents a wav file. |
Returnsβ
Nothing
Scopeβ
Vision Client
Code Examplesβ
Example #1
# This code would play a sound clip at full volume that was located on the current
# host's filesystem. It will not return until the clip in finished playing.
system.vision.playSoundClip("C:\\sounds\\siren.wav")
Example #2
# This code pulls a sound clip out of a BLOB field from a database
# and plays it asynchronously at half volume.
query = "SELECT wavBlob FROM sounds WHERE type = ?"
soundData = system.db.runScalarPrepQuery(query, ["alert_high"])
system.vision.playSoundClip(soundData, 0.5, 0)
