system.vision.getConnectionMode
Backwards Compatibility
This function replaces system.util.getConnectionMode. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility.
Descriptionβ
Retrieves this Client session's current connection mode. Possible connection modes are:
- 3: Read/Write
- 2: Read-only,
- 1: Disconnected
Syntaxβ
system.vision.getConnectionMode()
Parametersβ
Nothing
Returnsβ
Integer - The current connection mode for the Client.
Scopeβ
Vision Client
Code Examplesβ
Example #1
# This code will set a Client to read-only after a timeout of 30 seconds.
# Add this code to a Client timer script
mode = system.vision.getConnectionMode()
if mode == 3 and system.vision.getInactivitySeconds() > 30:
system.vision.setConnectionMode(2)
