Version: 8.1
system.gui.getWindow
Finds a reference to an open window with the given name. Throws a ValueError if the named window is not open or not found.
system.gui.getWindow(name)
StringnameThe path to the window to field.
Window - A reference to the window object, if it was open.
Vision Client
Example #1
# This example will get the window named 'Overview' and then close it.
try:
window = system.gui.getWindow('Overview')
system.gui.closeWindow(window)
except ValueError:
system.gui.warningBox("The Overview window isn't open")
Example #2
# This example will set a value on a label component in the 'Header' window.
try:
window = system.gui.getWindow('Header')
window.getRootContainer().getComponent('Label').text = "Machine 1 Starting"
except ValueError:
system.gui.warningBox("The Header window isn't open")
