system.gui.inputBox
Descriptionβ
Opens up a popup input dialog box. This dialog box will show a prompt message and allow the user to type in a string. When the user is done, they can click OK or Cancel. If OK is pressed, this function will return with the value that they typed in. If Cancel is pressed, this function will return the value None.
Syntaxβ
system.gui.inputBox(message, defaultText)
Parametersβ
| String | message | The message to display for the input box. Will accept HTML formatting. |
| String | defaultText | The default text to initialize the input box with. |
Returnsβ
String - The string value that was entered in the input box.
Scopeβ
Vision Client
Code Examplesβ
Example #1
# In the mouseClicked event of a label, this allows the user to change the label's text.
txt = system.gui.inputBox("Enter text:", event.source.text)
if txt != None:
event.source.text = txt
