system.sfc
SFC Functionsβ
The following functions give you access to interact with the SFCs in the Gateway.
ποΈ cancelChart
Cancels the execution of a running chart instance.
ποΈ getRunningCharts
Retrieves information about running charts.
ποΈ getVariables
Get the variables in a chart instance's scope.
ποΈ pauseChart
Pauses a running chart instance.
ποΈ redundantCheckpoint
Synchronizes chart and step variables of the specified chart instance across a redundant cluster.
ποΈ resumeChart
Resumes a chart that was paused.
ποΈ setVariable
Sets a variable inside a currently running chart.
ποΈ setVariables
Sets any number of variables inside a currently running chart.
ποΈ startChart
Starts a new instance of a chart.
Functions by Scopeβ
Chart Scope Variablesβ
There are a number of built-in variables maintained by the SFC engine that can be read through the chart scope. Some of the common built-in variables are shown in the table below.
Certain chart scoped variables may interfere with the internal functions of the chart. For example, creating a variable like chart.values will conflict with a pyDictionary's values() method and therefore the chart will show an error. Since SFC charts use Python Dictionaries to manage chart scoped variables, the methods associated with Python Dictionaries act like reserved words.
| Variable Name | Description |
| chart.instanceId | The string UUID of the running chart instance. |
| chart.startTime | A java.util.Date object that indicates when the chart instance started running. |
| chart.runningTime | An integer representing the number of seconds the chart has been running for. |
| chart.parent | The chart scope of the enclosing chart (if any). Null if this chart was not executed as part of an enclosing step. |
