system.sfc.cancelChart
Cancels the execution of a running chart instance. Any running steps will be told to stop, and the SFC chart will enter Canceling state. Will throw a KeyError if the ID does not match any running chart instance.
Permission Type: SFC Management
system.sfc.cancelChart(id)
| String | id | The ID of the chart instance to cancel. |
Nothing
Code Snippet
# The following attempts to stop an SFC but will alert the user if the id of the chart is not currently running.
id = 'Some long string value. It can be obtained using system.sfc.getRunningCharts()'
try:
except:
system.gui.messageBox("Could not stop the SFC")
