system.sfc.setVariables
Descriptionβ
Sets any number of variables inside a currently running chart.
Permission Type: SFC Management
Syntaxβ
system.sfc.setVariables(instanceId, [stepId], variableMap)
Parametersβ
| String | instanceId | The instance identifier of the chart. |
| String | stepId | The id for a step inside of a cart. If omitted the function will target a chart scoped variable. [optional] |
| Dictionary[String, Any] | variablesMap | A dictionary containing the name:value pairs of the variables to set. |
Returnsβ
Nothing
Scopeβ
Omitting the stepId parameter will cause the function to target a chart scoped variable. If the variable is persistent to the whole chart, or used in multiple different steps, then this parameter should be omitted.
If a stepId parameter is used, then the function will target a step scoped variable. The step associated with the stepId must be the currently active step.
Code Examplesβ
# Get the instance ID from the selected chart on a SFC Monitor component
id = event.source.parent.getComponent('SFC Monitor').instanceId
# Create a Python dictionary of values. This example assumes there are variables on the
# chart named chartParam and counter. The script will set these to 1, and 0 respectively
dict = {"chartParam":1, "counter":0}
# Set the variables on the chart
system.sfc.setVariables( id, dict)
