system.dnp3
The following functions use system.dnp3 and the Legacy DNP3 driver. See system.dnp for DNP3 functions using the DNP3 driver.
DNP3 Functions
The following functions give you access to interact with the DNP3 devices.
📄️ directOperateAnalog
Issues a Select-And-Operate command to set an analog value in an analog output point.
📄️ directOperateBinary
Issues a Direct-Operate command for digital control operations at binary output points (CROB).
📄️ freezeAnalogs
Issues a freeze command on the given analog outputs.
📄️ freezeAnalogsAtTime
Issues a freeze command on the given analog outputs at the given time for the specified duration.
📄️ freezeCounters
Issues a freeze command on the given counters.
📄️ freezeCountersAtTime
Issues a freeze command on the given counters at the given time for the specified duration.
📄️ selectOperateAnalog
📄️ selectOperateBinary
Issues a Select-And-Operate command for digital control operations at binary output points (CROB).
Functions by Scope
Constants
- system.dnp3.NUL = 0
- system.dnp3.PULSE_ON = 1
- system.dnp3.PULSE_OFF = 2
- system.dnp3.LATCH_ON = 3
- system.dnp3.LATCH_OFF = 4
- system.dnp3.CLOSE = 1
- system.dnp3.TRIP = 2
Status Codes
Many of the dnp3 functions return a status code. Those codes and their meaning are listed below.
Code Number | Identifier Name | Description |
0 | SUCCESS | Request accepted, initiated, or queued. |
1 | TIMEOUT | Request no accepted because the operate message was received after the arm timer timed out. The arm timer was started when the select operation for the same point was received. |
2 | NO_SELECT | Request no accepted because no previous matching select request exists. (An operate message was sent to activate an output that was not previously armed with a matching select message). |
3 | FORMAT_ERROR | Request not accepted because there were formatting errors in the control request (either select, operate, or direct operate). |
4 | NOT_SUPPORTED | Request not accepted because a control operation is not supported for this point. |
5 | ALREADY_ACTIVE | Request not accepted, because the control queue is full or the point is already active. |
6 | HARDWARE_ERROR | Request not accepted because of control hardware problems. |
7 | LOCAL | Request not accepted because Local/Remote switch is in Local position. |
8 | TOO_MANY_OBJS | Request not accepted because too many objects appeared in the same request. |
9 | NOT_AUTHORIZED | Request not accepted because of insufficient authorization. |
10 | AUTOMATION_INHIBIT | Request not accepted because it was prevented or inhibited by a local automation process. |
11 | PROCESSING_LIMITED | Request not accepted because the device cannot process any more activities than are presently in progress. |
12 | OUT_OF_RANGE | Request not accepted because the value is outside the acceptable range permitted for this point. |
13 to 125 | RESERVED | Reserved for future use. |
126 | NON_PARTICIPATING | Sent in request messages indicating that the outstation will not issue or perform the control operation. |
127 | UNDEFINED | Request not accepted because of some other undefined reason. |
