system.dnp3.freezeCountersAtTime
note
The following function uses system.dnp3 and the Legacy DNP3 driver. See system.dnp for DNP3 functions using the DNP3 driver.
Descriptionβ
Issues a freeze command on the given counters at the given time for the specified duration.
Permission Type: DNP3 Management
Syntaxβ
system.dnp3.freezeCountersAtTime(deviceName, absoluteTime, intervalTime, indexes)
Parametersβ
| String | deviceName | The name of the DNP3 device driver. |
| Integer | absoluteTime | The absolute time at which to freeze, in millis. |
| Integer | intervalTime | The interval at which to periodically freeze, in millis. |
| List | indexes | A list of specific indexes on which to issue the freeze command. An empty list will freeze all counters. |
Returnsβ
Nothing
Scopeβ
Code Examplesβ
Example #1
# This example shows a request to freeze counters at indexes 2 and 4,
# 5 minutes from the current time, with no interval.
from time import *
fiveMikes = (60 * 1000 * 5) + int(time() * 1000) #ms
system.dnp3.freezeCountersAtTime("Dnp3", fiveMikes, 0, [2, 4])
