system.dnp3.freezeAnalogs
note
The following function uses system.dnp3 and the Legacy DNP3 driver. See system.dnp for DNP3 functions using the DNP3 driver.
Descriptionβ
Issues a freeze command on the given analog outputs.
Permission Type: DNP3 Management
Syntaxβ
system.dnp3.freezeAnalogs(deviceName, [indexes])
Parametersβ
| String | deviceName | The name of the DNP3 device driver. |
| List | indexes | A list of specific indexes on which to issue the freeze command. An empty list can be passed to freeze all analogs. |
Returnsβ
Nothing
Scopeβ
Code Examplesβ
Example #1
# This example shows a request to freeze all analog inputs in the outstation.
system.dnp3.freezeAnalogs("Dnp3", [])
Example #12
# This example shows a request to freeze analog inputs at indexes 1, 3, and 5.
system.dnp3.freezeAnalogs("Dnp3", [1, 3, 5])
