Version: 8.1
system.dnp3.freezeAnalogsAtTime
note
The following function uses system.dnp3 and the Legacy DNP3 driver. See system.dnp for DNP3 functions using the DNP3 driver.
Issues a freeze command on the given analog outputs at the given time for the specified duration.
Permission Type: DNP3 Management
system.dnp3.freezeAnalogsAtTime(deviceName, absoluteTime, intervalTime, indexes)
StringdeviceNameThe name of the DNP3 device driver.
IntegerabsoluteTimeThe absolute time at which to freeze, in millis.
IntegerintervalTimeThe interval at which to periodically freeze, in millis.
ListindexesA list of specific indexes on which to issue the freeze command. An empty list will freeze all points.
Nothing
Example #1
# This example shows a request to freeze analog inputs at indexes 2 and 4,
# 5 minutes from the current time, with no interval.
from time import *
fiveMikes = (60 * 1000 * 5) + int(time() * 1000) #ms
system.dnp3.freezeAnalogsAtTime("Dnp3", fiveMikes, 0, [2, 4])
