system.sfc.setVariables
Sets any number of variables inside a currently running chart.
Permission Type: SFC Management
system.sfc.setVariables(instanceId, [stepId], variableMap)
StringinstanceIdThe instance identifier of the chart.
StringstepIdThe id for a step inside of a chart. If omitted the function will target a chart scoped variable. [Optional]
PyObjectvariablesMapA dictionary containing the name:value pairs of the variables to set.
Nothing
All
note
Omitting the stepId parameter will cause the function to target a chart scoped variable. If the variable is persistent to the whole chart, or used in multiple different steps, then this parameter should be omitted.
If a stepId parameter is used, then the function will target a step scoped variable. The step associated with the stepId must be the currently active step.
Code Snippet
# Get the instance ID from the selected chart on a SFC Monitor component
id = event.source.parent.getComponent('SFC Monitor').instanceId
# Create a Python dictionary of values. This example assumes there are variables on the
# chart named chartParam and counter. The script will set these to 1, and 0 respectively
dict = {"chartParam":1, "counter":0}
# Set the variables on the chart
system.sfc.setVariables( id, dict)
