system.opchda
OPC HDA Functions
The following functions give you access to interact with the HDA types of OPC servers.
📄️ system.opchda.browse
Performs a browse at the given root.
📄️ system.opchda.getAggregates
Will query the server for aggregates that it supports.
📄️ system.opchda.getAttributes
Queries the given server for the item attributes that are available with system.opchda.readAttributes.
📄️ system.opchda.getServers
Returns a list of the OPC-HDA servers configured on the system.
📄️ system.opchda.insert
Insert values on the OPC-HDA server if the given item ID does not exist.
📄️ system.opchda.insertReplace
Will insert values on the OPC-HDA server, or replace them if they already exist.
📄️ system.opchda.isServerAvailable
Checks to see if the specified OPC-HDA server is defined, enabled, and connected.
📄️ system.opchda.readAttributes
Reads the specified attributes for the given item over a time range.
📄️ system.opchda.readProcessed
Reads processed values from the OPC-HDA server.
📄️ system.opchda.readRaw
Reads raw values from the OPC-HDA server.
📄️ system.opchda.replace
Replaces values on the OPC-HDA server if the given item ID exists.
Functions by Scope
No functions found for this category.
