system.opchda.insertReplace
Will insert values on the OPC-HDA server, or replace them if they already exist.
Permission Type: OPC Server Management
system.opchda.insertReplace(serverName, itemId, value, date, quality)
StringserverNameThe name of the defined OPC-HDA server.
StringitemIdThe item ID to perform the operation on.
ObjectvalueThe value to insert or replace.
ObjectdateThe date to insert or replace.
QualityCodequalityThe quality to insert or replace.
QualityCode - The result of the insert or replace operation.
All
