system.opchda.readRaw
Reads raw values from the OPC-HDA server.
system.opchda.readRaw(serverName, itemIds, startDate, endDate, maxValues, boundingValues)
StringserverNameThe name of the defined OPC-HDA server to read.
ListitemIdsA list of item ids to read.
ObjectstartDateThe starting date/time of the query.
ObjectendDateThe ending date/time of the query.
intmaxValuesThe maximum number of values to return. 0 or less means unlimited.
BooleanboundingValuesA boolean indicating whether or not the "bounding values" should be included in the result set. The bounding values provide a value exactly at the start and end dates, but may be resource-intensive to retrieve.
ReadResults[] - A list of read results which is one-to-one with the item IDs passed in. The ReadResult object has a serviceResult quality property that indicates whether the call was successful, and is itself a list of QualifiedValues.
All
