system.opchda.readAttributes
Reads the specified attributes for the given item over a time range. Attributes and their IDs are defined in the OPC-HDA specification, and can be discovered by calling system.opchda.getAttributes().
system.opchda.readAttributes(serverName, itemId, attributeIds, startDate, endDate)
StringserverNameThe name of the defined OPC-HDA server to read.
StringitemIdThe itemID to retrieve attributes for.
StringattributeIdsThe integer IDs of the attributes to read. The attribute ids are defined in the OPC-HDA specification. The attributes can also be obtained by calling system.opchda.getAttributes(). Some servers may not support all attributes.
StringstartDateThe starting date/time of the query.
StringendDateThe ending date/time of the query.
ReadResults[] - A list of read results which is one-to-one with the requested attributes. The ReadResult object has a serviceResult quality property that indicates whether the call was successful, and is itself a list of QualifiedValues.
All
