system.opchda.readAttributes
Descriptionβ
Reads the specified attributes for the given item over a time range. Attributes and their IDs are defined in the OPC-HDA specification, and can be discovered by calling system.opchda.getAttributes().
Syntaxβ
system.opchda.readAttributes(serverName, itemId, attributeIds, startDate, endDate)
Parametersβ
| String | serverName | The name of the defined OPC-HDA server to read. |
| String | itemId | The itemID to retrieve attributes for. |
| List[String] | attributeIds | The integer IDs of the attributes to read. The attribute ids are defined in the OPC-HDA specification. The attributes can also be obtained by calling system.opchda.getAttributes(). Some servers may not support all attributes. |
| String (can be other data types, such as int) | startDate | The starting date/time of the query. |
| String (can be other data types, such as int) | endDate | The ending date/time of the query. |
Returnsβ
List[ReadResults] - A list of read results which is one-to-one with the requested attributes. The ReadResult object has a serviceResult quality property that indicates whether the call was successful, and it is itself a list of QualifiedValues.
Scopeβ
Code Examplesβ
Example #1
# This example will get user-specified attributes over a period of time from a Matrikon OPC HDA explorer.
# Declare start and end dates
start = system.date.getDate(2022, 10, 24)
end = system.date.getDate(2022, 10, 24)
# Call the system function
hda = system.opchda.readAttributes('Matrikon HDA','1',[1],start,end)
print hda
