system.opchda.replace
Description
Replaces values on the OPC-HDA server if the given item ID exists.
Client Permission Restrictions
Permission Type: OPC Server Management
Syntax
system.opchda.replace(serverName, itemId, value, date, quality)
Parameters
StringserverNameThe name of the defined OPC-HDA server.
StringitemIdThe item ID to perform the operation on.
ObjectvalueThe value to replace.
ObjectdateThe date to replace.
intqualityThe quality to replace.
Returns
int - The items quality resulting from the operation.
Scope
All
