system.opchda.replace
Descriptionβ
Replaces values on the OPC-HDA server if the given item ID exists.
Permission Type: OPC Server Management
Syntaxβ
system.opchda.replace(serverName, itemId, value, date, quality)
Parametersβ
| String | serverName | The name of the defined OPC-HDA server. |
| String | itemId | The item ID to perform the operation on. |
| Object | value | The value to replace. |
| Object | date | The date to replace. |
| Integer | quality | The quality to replace. |
Returnsβ
Integer - The items quality resulting from the operation.
Scopeβ
