system.opc.writeValues
This function is a bulk version of system.opc.writeValue. It takes a list of addresses and a list of objects, which must be the same length. It will write the corresponding object to the corresponding address in bulk. It will return a list of status codes representing the individual write success or failure for each corresponding address.
Permission Type:: OPC Server Management
system.opc.writeValues(opcServer, itemPaths, values)
StringopcServerThe name of the OPC server connection in which the items reside.
String[]itemPathsA list of item paths, or addresses, to write to.
Object[]valuesA list of values to write to each address specified.
Quality[] - An array of Quality objects, each entry corresponding in order to the addresses specified.
All
