system.opc.writeValue
Writes a value directly through an OPC server connection synchronously. Will return an OPC-UA status code object. You can quickly check if the write succeeded by calling isGood() on the return value from this function.
Permission Type: OPC Server Management
system.opc.writeValue(opcServer, itemPath, value)
StringopcServerThe name of the OPC server connection in which the item resides.
StringitemPathThe item path, or address, to write to.
ObjectvalueThe value to write to the OPC item.
Quality - The status of the write. Use returnValue.isGood() to check if the write succeeded.
All
Code Snippet
server = "Ignition OPC-UA Server"
path = "[SLCSim]_Meta:N7/N7:0"
oldQualifiedValue = system.opc.readValue(server, path)
newValue = oldQualifiedValue.getValue() + 1
returnQuality = system.opc.writeValue(server, path, newValue)
if returnQuality.isGood():
print "Write was successful"
else:
print "Write failed"
