Version: 8.1
system.opc.writeValue
Writes a value directly through an OPC server connection synchronously. Will return an OPC UA status code object. You can quickly check if the write succeeded by calling isGood() on the return value from this function.
New in 8.1.27
Supplying a QualifiedValue to this system function will cause the DataValue to include the QualifiedValue's corresponding StatusCode when the DataValue is sent to the server.
Permission Type: OPC Server Management
system.opc.writeValue(opcServer, itemPath, value)
StringopcServerThe name of the OPC server connection in which the item resides.
StringitemPathThe item path, or address, to write to.
ObjectvalueThe value to write to the OPC item.
Quality - The status of the write. Use returnValue.isGood() to check if the write succeeded. Refer to the list of writeValue objects.
Code Snippet - Writing to an OPC Value
# This example will write to an OPC Tag that is on a provider called SLCSim
# Declare the server name
server = "Ignition OPC UA Server"
# Declare the Tag path
path = "[SLCSim]_Meta:N7/N7:0"
# Declare the system function parameters
oldQualifiedValue = system.opc.readValue(server, path)
newValue = oldQualifiedValue.getValue() + 1
# Call the system function and print out results
returnQuality = system.opc.writeValue(server, path, newValue)
if returnQuality.isGood():
print "Write was successful"
else:
print "Write failed"
