system.opc.writeValues
This function is a bulk version of system.opc.writeValue. It takes a list of addresses and a list of objects, which must be the same length. It will write the corresponding object to the corresponding address in bulk. It will return a list of status codes representing the individual write success or failure for each corresponding address.
Permission Type: OPC Server Management
system.opc.writeValues(opcServer, itemPaths, values)
Type | Parameter | Description |
String | opcServer | The name of the OPC server connection in which the items reside. |
List[String] | itemPaths | A list of item paths, or addresses, to write to. |
List[Any] | values | A list of values to write to each address specified. |
List[Quality] - An array of Quality objects, each entry corresponding in order to the addresses specified. Refer to the list of writeValues objects.
# This example will write values to specified OPC items
# Declare a list of values
objectValue = [3]
# Declare the item path to write values back to
itemPath = "ns=1;s=[GoldSim]B3/B3:100"
# Write the values to the specified item. Replace "Ignition OPC UA Server" with your chosen OPC UA server.
system.opc.writeValues("Ignition OPC UA Server", itemPath, objectValue)
