system.opc.writeValue
Descriptionβ
Writes a value directly through an OPC server connection synchronously. Will return an OPC UA status code object. You can quickly check if the write succeeded by calling isGood() on the return value from this function.
Supplying a QualifiedValue to this system function will cause the DataValue to include the QualifiedValue's corresponding StatusCode when the DataValue is sent to the server.
Permission Type: OPC Server Management
Syntaxβ
system.opc.writeValue(opcServer, itemPath, value)
Parametersβ
| String | opcServer | The name of the OPC server connection in which the item resides. |
| String | itemPath | The item path, or address, to write to. |
| Object | value | The value to write to the OPC item. |
Returnsβ
Quality - The status of the write. Use returnValue.isGood() to check if the write succeeded. Refer to the list of writeValue objects.
Scopeβ
Code Examplesβ
# This example will write to an OPC Tag that is on a provider called SLCSim
# Declare the server name
server = "Ignition OPC UA Server"
# Declare the Tag path
path = "[SLCSim]_Meta:N7/N7:0"
# Declare the system function parameters
oldQualifiedValue = system.opc.readValue(server, path)
newValue = oldQualifiedValue.getValue() + 1
# Call the system function and print out results
returnQuality = system.opc.writeValue(server, path, newValue)
if returnQuality.isGood():
print "Write was successful"
else:
print "Write failed"
