system.opc.browseServer
When called from a Vision Client, returns a list of OPCBrowseElement objects for the given server. Otherwise returns a list of OPCBrowseElements.
The OPCBrowseElement object has the following methods:
  • getDisplayName() - returns the display name of the object
  • getElementType() - returns the element type. Element types are server, device, view, folder, object, datavariable, property and method.
  • getNodeId() - returns a string representing the server node ID
The PyOPCTag object has the following methods to retrieve information:
  • getServerName() - returns the server name as a string.
system.opc.browseServer(opcServer, nodeId)
StringopcServerThe name of the OPC server connection.
StringnodeIdThe node ID to browse.
List - A list of PyOPCTag objects.
Gateway
Syntax - Vision Client Scope​
List - A list of OPCBrowseElement objects.
Client
Code Snippet
# Print the name of all devices on Ignition OPC-UA
opcServer="Ignition OPC-UA Server"
nodeId = "Devices"
devices = system.opc.browseServer(opcServer, nodeId)
for device in devices:
print device.getDisplayName()
