system.sfc.startChart
Starts a new instance of a chart. The chart must be set to "Callable" execution mode.
Permission Type: SFC Management
system.sfc.startChart(path, arguments)
StringpathThe path to the chart, for example "ChartFolder/ChartName".
DictionaryargumentsA dictionary of arguments. Each key-value pair in the dictionary becomes a variable in the chart scope and will override any default.
String - The unique ID of this chart.
All
Code Snippet
# The following will start an SFC with a dictionary of values to use inside the chart
args= {"var1":10, "Var2":15,"Var3":1}
path = "ChartFolder/ChartName"
sfcID = system.sfc.startChart(path, args)
