system.sfc.cancelChart
Cancels the execution of a running chart instance. Any running steps will be told to stop, and the chart will enter Canceling state.
Permission Type: SFC Management
system.sfc.cancelChart(id)
StringidThe ID of the chart instance to cancel.
Nothing
Throws​
Will throw a KeyError if the ID does not match any running chart instance.
All
Example #1
# The following will attempt to stop an SFC but will alert the user if the id of the chart is not currently running
id = 'Some long string value obtained from earlier in the script'
try:
except:
system.gui.messageBox("Could not stop the SFC")
