Version: 8.3
system.sfc.startChart
Starts a new instance of a chart. The chart must be set to "Callable" execution mode.
Permission Type: SFC Management
system.sfc.startChart(projectName, chartPath, parameters)
StringprojectNameThe name of the project that the chart was created in. The project that this function is called in will be used if no name is provided, or if the function is called from outside a project, the default Gateway project name will be used.
StringchartPathThe path to the chart, for example "ChartFolder/ChartName".
Dictionary[String, Any]parametersA dictionary of arguments. Each key-value pair in the dictionary becomes a variable in the chart scope and will override any default.
String - The unique ID of this chart.
Code Snippet
# The following will start an SFC with a dictionary of values to use inside the chart
args= {"var1":10, "Var2":15,"Var3":1}
path = "ChartFolder/ChartName"
sfcID = system.sfc.startChart(path, args)
