system.sfc.redundantCheckpoint
Descriptionβ
Synchronizes chart and step variables of the specified chart instance across a redundant cluster, allowing the chart instance to continue where it left off if a redundant failover occurs. Check out redundancy sync for more information.
Permission Type: SFC Management
Syntaxβ
system.sfc.redundantCheckpoint(instanceId)
Parametersβ
| String | instanceId | The instance identifier of the chart. |
Returnsβ
Nothing
Scopeβ
Code Examplesβ
Code Snippet
# This example will create a redundant checkpoint in case the primary Gateway in the redundant pair fails.
instanceId = "The ID of the chart you want to synchronize across the redundant pair"
