Version: 8.3
system.sfc
SFC Functions​
The following functions give you access to interact with the SFCs in the Gateway.
Functions by Scope​
Chart Scope Variables​
There are a number of built-in variables maintained by the SFC engine that can be read through the chart scope. Some of the common built-in variables are shown in the table below.
note
Certain chart scoped variables may interfere with the internal functions of the chart. For example, creating a variable like chart.values will conflict with a pyDictionary's values() method and therefore the chart will show an error. Since SFC charts use Python Dictionaries to manage chart scoped variables, the methods associated with Python Dictionaries act like reserved words.
Variable NameDescription
chart.instanceIdThe string UUID of the running chart instance.
chart.startTimeA java.util.Date object that indicates when the chart instance started running.
chart.runningTimeAn integer representing the number of seconds the chart has been running for.
chart.parentThe chart scope of the enclosing chart (if any). Null if this chart was not executed as part of an enclosing step.
