system.dnp
The following functions use system.dnp and the DNP3 driver. See system.dnp3 for DNP3 functions using the Legacy DNP3 driver.
DNP Functionsβ
The following functions give you access to interact with the DNP3 devices.
ποΈ demandPoll
Issues a poll request for one or more classes.
ποΈ directOperateAnalog
Performs a Direct Operate command on an analog point.
ποΈ directOperateBinary
Performs a Direct Operate command on a binary point.
ποΈ freezeAnalogs
Issues an Immediate Freeze command targeting one or more analog points.
ποΈ freezeAtTimeAnalogs
Issues a Freeze at Time command targeting one or more analog points.
ποΈ freezeAtTimeCounters
Issues a Freeze at Time command targeting one or more counters.
ποΈ freezeClearAnalogs
Issues a Freeze and Clear command targeting one or more analog points.
ποΈ freezeClearCounters
Issues a Freeze and Clear command targeting one or more counters.
ποΈ freezeCounters
Issues an Immediate Freeze command targeting one or more counters.
ποΈ selectOperateAnalog
Performs a Select then Operate command on an analog point.
ποΈ selectOperateBinary
Performs a Select then Operate command on a binary point.
ποΈ synchronizeTime
Issues a Synchronize Time command using the current Ignition Gateway time.
