system.gui.inputBox
Opens up a popup input dialog box. This dialog box will show a prompt message, and allow the user to type in a string. When the user is done, they can press "OK" or "Cancel". If OK is pressed, this function will return with the value that they typed in. If Cancel is pressed, this function will return the value None.
system.gui.inputBox(message, defaultText)
StringmessageThe message to display for the input box. Will accept html formatting.
StringdefaultTextThe default text to initialize the input box with.
String - The string value that was entered in the input box.
Client
Example #1
# This could go in the mouseClicked event of a label to allow the user to change the label's text.
txt = system.gui.inputBox("Enter text:", event.source.text)
if txt != None:
event.source.text = txt
