system.gui.isTouchscreenModeEnabled
Checks whether or not the running client's touchscreen mode is currently enabled.
system.gui.isTouchscreenModeEnabled()
None
boolean - True(1) if the client currently has touchscreen mode activated.
All
Example #1
# This example should be used in the Client Startup Script to check if this client is being run on a touch screen computer (judged by an IP address) and set touchscreen mode.
ipAddress = system.net.getIpAddress()
query = "SELECT COUNT(*) FROM touchscreen_computer_ips WHERE ip_address = '%s' "
isTouchscreen = system.db.runScalarQuery(query %(ipAddress))
if isTouchscreen and not system.gui.isTouchscreenModeEnabled():
system.gui.setTouchscreenModeEnabled(1)
