system.gui.getSibling
Given a component event object, looks up a sibling component. Shortcut for event.source.parent.getComponent("siblingName"). If no such sibling is found, the special value None is returned.
system.gui.getSibling(event, name)
EventObjecteventA component event object.
StringnameThe name of the sibling component.
PyObject - The sibling component itself.
Client
Example #1
# This example will get its sibling Text Field's text, and use it.
textField = system.gui.getSibling(event, 'TextField (1)')
if textField is None:
system.gui.errorBox("There is no text field!")
else:
system.gui.messageBox("You typed: %s" % textField.text)
